Is a Lewmar 24 2-Speed Winch too big for an O'day 22?
64
Cal 29 Lake Saint Clair - SCS
I know a guy that will sell me his pair of Lewmar 24 2-speed chrome winches (older, heavy style) for $250. I just am not sure if it would be too much winch power for my little boat, and if I would be better off with two lighter one speed winches.
Please reply, all comments are welcome!
4,881
Oday 222 Dighton, Ma.
I would be more concerned with whether these winches are going to look too big bolted to the combings on your boat. I thought that my Barlow winches were #13s but I suppose they could be #15s. I'll check tomorrow and get you some outside dimensions that you can go by.
Mar 25, 2010
64
Thanks for replying. Here are the dimensions:
Drum Diameter 2 1/2". Base Diameter 4 3/4". 4 3/4 Tall.
Mar 25, 2010
64
I thought I'd get more replies... oh well. I just paypal'd him the money. Whether they are too big or not, I'm installing the 24's. Any suggestions on a perfect place to mount them? I've attached a photo if that helps.
4,881
I'm sure they'll look fine. As for where to mount them; what I would do is stand in the cockpit at the tiller and lay the winch on the combing. You want it within a comfortable reaching distance from the helm. There aren't too many choices as to where you can place them, but those horn cleats will have to be removed. I would also place a large open clam cleat directly behind each winch. You'll love them, believe me. My friend Wayne had jam cleats behind the winches on his Seaward 22 and he replaced them with clam cleats and he loves them. Most of the time you're going to use these winches like capstans, operating them without a winch handle. You'll get into a steady routine while sailing single handed. You'll tack and release the sheet from the clam cleat as she goes over on the new tack, and pull the sheet straight up off the winch. As she settles in on the new tack, you'll put a single turn of the sheet around the winch, pull the slack out and put two more turns around the winch, set the sail, and put the sheet in the clam cleat. If you're beating up wind, this becomes automatic. You don't even have to touch your main sheet. Just let the Mainsail come around by itself. This is why it's so important to have the winches within a comfortable reaching distance. I have a Davis Windex on a 12" extension bracket at the top of my mast and I'm constantly checking it, especially when I'm sailing down wind. Good luck!
Joe
Dec 8, 2006
1,085
Oday 26 Starr, SC
yes, they are overkill
Yes, 24 of anybrand is overkill for a smaller boat. However, since you are commited get piece of HDPE about 1" thick and mount winchs to Hdpe and mount hdpe on gunnells. At same time make sure piece hdpe is long enough to mount cleats on it too.
So how wide is your gunnell? does it narrow as it goes back? shape the Hdpe to fit the gunnell and use four bolts to bolt it to gunnell. Can you get under gunnell where you will mount Hdpe to use backing? Piece of marine or exterion 1/2 " plywood would work as backing. If you use plywood, seal before using.
With winches that big maybe you need to get bigger line for sheets?
Ed K
26
