Two different objectives
There are a lot of opinions on this subject, and none of them are wrong. So I thought I would add mine.I use 5200 when I need something bonded (glued, stuck, attached, adhered, fastened, etc…) as the primary attatchment, as well as sealed.I use 4200 for sealing items that are mechanically attached (screwed, bolted, retained, nailed, clamped, etc…) and just need a waterproof seal. Hopefully, things like thru-hulls, transducers, and stanchions are mechanically secured. If the additional security of 5200 is required on mechanically fastened hardware, I would think that the attachment design was flawed. Hull-to-deck joints are a good example of this. The 1/4 inch bolts and screws used with the fiberglass material on my boat would be insufficient alone, and so requires bonding to add enough strength in this highly loaded area
