Irwin Steering Cables
4
Irwin 42 Ketch Cocoa Beach
I am looking for a set of steering cables for a 1975 Irwin 42 ketch. The 7/19 wire is 3/16" x 18 feet. (20 ft to allow cutting to correct length)
The cable housing is 14.5 ft 9/16" dia o.d. & 1/4 " i.d. Due to the age of the vessel, the fittings used to secure the cable housing to the mounting brackets is an issue. I may need to replace those as well to accommodate the new fittings. If any one knows of a source, please reply. Thanks, Cal
Jul 12, 2010
4
ps I have already been in touch with Edson. The fittings are the issue with them also. I have photos available on request.
Oct 6, 2008
857
Hunter, Island Packet, Catalina, San Juan 26,38,22,23 Kettle Falls, Washington
Any industrial cable, wire or fastener business will have the cable you need in stock. They can also probably steer you to a business that can help with the housing tubing and related parts. They might look a little different but will work. Any electrician can bend the tubing as needed.
Good luck, it looks like an interesting winter project.
Ray
