iPad/Chartplotter Display
Nov 21, 2024
5
Gulf Yachts 30 Mandeville
Hi Fellow Sailors !! I have a navigation/computer question. I use the iNavX app for online use at home, plotting routes, etc. Is it possible, using the iNavX app, to get live GPS location on an iPad 11th generation (2025) ? Is there a different app I should use ? My goal is to use my iPad, offline, as a chartplotter, using a USB Type C GPS antenna. All help is greatly appreciated !! Happy Thanksgiving !!
Apr 11, 2010
998
Hunter 38 Whitehall MI
I’ve been running INavX on an iPad for many years now. I have an external GPS antenna and AIS antenna that are wired into a Digital Yachts hub. The hub provides a wifi signal to the iPad which I use at the helm.
The display shows all the navigation features. The AIS is a class B transponder / reciever so I’m broadcasting my position and receiving from others. All displayed on iPad
No reason to believe it will not work. If you are wondering, step outside with your iPad and test it in front of your house. I have used it as a chart plotter on my iPhone.
Turn your iPhone into a real chartplotter.
Professional-grade navigation, anywhere you boat. iNavX gives you worldwide charts, route planning, live AIS, and GRIB weather in one app.
iNavx
iPads with cellular data capability have a gps chip and can display gps data on screen. I use it on my iPad with Aquamaps, I would assume that it can work with iNavX too. GPS data from the cell phone chip is not quite as accurate as modern chart plotters because the chart plotters use multiple satellite systems.
The specific answer to your question is it depends on whether your iPad has a cell data chip in it.
colemj
Jul 13, 2004
1,185
If you plan to use an external GPS, then it doesn't matter if your iPad has an internal GPS or not. But I'd get an external GPS that communicates with the iPad wirelessly rather than tethered to a USB cable.
Mark
