Invest 95L --> TD #2 --> TS Beryl --> Hurricane Beryl
JamesG161
Feb 14, 2014
7,561
Hunter 430 Waveland, MS
This bears watching for sure.
We are posting 96 hours models today or 3 days out.
Both GFS [NOAA] and ECMWF [European] are almost matching.
GFS first...
_____________
ECMWF model...
This will be Named BERYL or pronounced "Bear Rill"
More info coming each day on this Storm.
But showing the Hurricane Fuel or HEAT today.
So time to prepare for the Season now.
Jim and John
PS:
Hurricane Preparedness
WayneH
Tartan 37 287 Pensacola, FL
I've been watching this one for a while. It looks like it is going to mess up my family reunion week and cause me to drive the 3/4 ton pickup halfway across the country. UGH! This might be the one time I hope it hits Central Texas. The lakes around here are low. Lake Medina is at 2.3% of conservation level.
JamesG161
Feb 14, 2014
7,561
My Bet is on the ECMWF Model.
John and I bet different.
3 more days Wayne, but your reunion in Central Texas should be ok. [I hope :biggrin:]
Windy.com will be your best bet for the reunion forecast.
Jim...
JamesG161
Feb 14, 2014
7,561
Now just happened ....
Tropical Depression #2
Here we go for a fun filed July 4th week.
Jim...
Wayne, If your reunion is in Texas around 5 July, you should be ok no matter which model you follow. Here is the forecasted storm location for 5 July 2024. It is seven days away, and anything can happen. There is even talk about Invest 95L blowing through the Lesser Antilles and dying in the Caribbean Sea. The rationale for observing this storm and getting prepared to address such events is to prepare now so you're not rushing when supplies might be gone at the last minute.
Likes: JamesG161
Jim & John, looking at the OHI it looks to me that the North Atlantic doesn't have as much heat as feared. But I don't have a sense of what normal is. The tropical Atlantic looks very warm, as does the Caribbean and that tongue of warm water in the Gulf. But again how abnormal is that?
JamesG161
Feb 14, 2014
7,561
Let me do a Separate Post on HEAT and Surface Temperatures. The tongue of water = Gulf Stream.
Jim...
JamesG161
Feb 14, 2014
7,561
Tropical Storm Beryl is forecast to be 2024 first Hurricane.
There is a Second Tropical wave following it. John told me it was like a "Comet's Tail" trailing behind Beryl.
ECMWF model is the best to follow for now.
48 hours forecast
When the Hurricane Hunters fly into the Storm we will know much more data.
Jim...
JamesG161
Feb 14, 2014
7,561
Hurricane Beryl
It is small and compact moving West at 23 mph.
The Hurricane Hunters heading to the Storm now.
Island impact still 1.5 days away.
Check back for more information soon.
Dammit Jim...
JamesG161
Feb 14, 2014
7,561
This is the first data from the Recon Flight into Beryl
Small Eye formed in this Compact Storm.
The 96 hour path takes it over the HEAT fuels area.
Dammit Jim...
JamesG161
Feb 14, 2014
7,561
The fact that Beyrl so Compact , many of the Islands will not even see tropical force winds.
Note Last Pictograph, above.
Dammit Jim...
