Invest 92L
JamesG161
Feb 14, 2014
7,770
Hunter 430 Waveland, MS
Alert out now and the Hurricane Hunters left from Kessler AFB at 5:00am CST.
They are surveying the storm now.
We are monitoring this fixed station on the path now.
NDBC - Station 41117 Recent Data
New warnings soon!
Jim...
WayneH
Tartan 37 287 Pensacola, FL
Technology: Being able to tell the wind is blowing 15-20 knots from starboard while moving forward at 300 knots. :wow3:
capta
Jun 4, 2009
4,935
Let's just hope that it won't stop and "cook" in the Gulfstream for a couple of days.
JamesG161
Feb 14, 2014
7,770
:plus::plus:
But Invest 92L is doing this now.
Raining out as it comes ashore. :clap:
Jim...
PS: Hurricane Hunter heading back home.
Technology:
Yes It is amazing.
Using dropwindsondes.
P-3 Orion: Into the Storm
Four-engine propeller plane in the air
Slicing through the eyewall of a hurricane, buffeted by howling winds, blinding rain and violent updrafts and downdrafts before entering the relative calm of the storm’s eye, NOAA’s two Lockheed WP-3D Orion four-engine turboprop aircraft, affectionately nicknamed "Kermit" (N42RF) and "Miss Piggy" (N43RF), probe every wind and pressure change, repeating the often grueling experience again and again during the course of an 8-10 hour mission.
Scientists aboard the aircraft deploy Global Positioning System (GPS) dropwindsondes as NOAA Corps officers pilot and navigate the P-3 through the hurricane. These instruments continuously transmit measurements of pressure, humidity, temperature, and wind direction and speed as they fall toward the sea, providing a detailed look at the structure of the storm and its intensity. The P-3s' tail Doppler radar and lower fuselage radar systems, meanwhile, scan the storm vertically and horizontally, giving scientists and forecasters a real-time look at the storm. The P-3s can also deploy probes called bathythermographs that measure the temperature of the sea.
Likes: JamesG161
WayneH
I knew about the drop sondes. But I was looking at the recon map and there are wind barbs from where they launched out to sea. And there are a lot more wind barbs than there are available drops. So how do they measure wind speed and direction without a dropsonde?
JamesG161
Feb 14, 2014
7,770
opps @WayneH
Update the post for more info on NOAA Aircraft.
As a Moderator i was updating without showing the update
My Bad...:facepalm:
capta
Jun 4, 2009
4,935
We had some pretty violent unforecasted weather pass through Charleston one day when I lived there. Years later the powers that be were still undecided as to whether it was a hurricane or not.
Today in South Florida there were basically random showers including some zitt/boom events but no wind. Rain was at times heavy but not unusually so here. Not sure if this weather is related to the on/off tropical event off Jacksonville.
I'll venture you Charlestown folks don't have to go to ground (Well there's no ground to go to!).
Listen to some CCR "Have you ever seen the rain" and chill.
Johann
Jun 3, 2004
511
Leopard 39 Pensacola
The barbs are flight level winds. They are calculated by comparing the aircraft true airspeed and heading with the ground speed and ground track.
