Replace & Upgrade
I would recommend replacing the inverter with a new Hart and even go up to a next larger size. Check all the wiring and you might consider sending the old inverter back to Hart to find out what happened to the old one. When you install the new one, I strongly recommend that you also put in the Link 1000 battery monitor. I severly abused the batteries that came on our boat when new and they only lasted two years because I didn't have the Link. Also, if your current house batteries are over two years old, consider replacing them with Absorbed Glass Mat (AGM) type. You will get more capacity, longer life and faster charging, which is very important when cruising. I love my inverter because it allows me to run the ice maker 24 hours a day (ice for the rum at 1700 hours and homemade ice cream on the hook). Good luck and post your final decision.
