It seems that inverters are a must-have component of most people's electrical systems. They also seem to be the most power-hungry any inefficient device you could connect your battery bank.
What are most people using them for?
Maybe it's because I came from a trailer sailing background - but everything I use runs from 12 volts.
- TV is 12 volt and only draws 1.5 amp (22 inch flat screen)
- cordless drill charges directly from 12 volts
- laptop is 12 volt (9.6volts battery replacement - 800 ma in use)
- all other chargers are 12 volt
I compared AC via an inverter to my 12 volt draw and in most cases the inverter/AC solution drew twice the current.
My biggest challenge was for the computer. As a software developer who wants to "work aboard" I needed a solution that worked for me.
Initially the battery replacement and using the TV as a second monitor was the ticket (2.3 amps).
Now that decent development tools and MS Office is available on the Chromebook, I can do 90 percent of my work on it and "remote" to my other land based machines for the 10 percent. It charges and runs from a USB port at 200 ma once charged - quite acceptable.
I keep getting asked "what kind of inverter I'm putting in" from people who have ones that can cold start a 747.
I just can't figure out what I'd want to plug into one - other than possibly a small microwave (curious what a typical daily draw would be for one).
Help me understand,
Chris
Help me understand,
Chris
