I bought a Xantrex Freedom inverter/charger and paid $800 to have it "professionally" installed - as I am uncomfortable working with AC power. I thought it would be set up so that when I'm plugged into shore power I'm using my AC outlets and the charger is busy charging the batteries, and when I'm not plugged in my AC outlets would still work so I could use my computer, watch t.v. etc. The brochure implied that the inverter would automatically switch over, and that I just needed to be smart enough to make sure and turn off the water heater....
Instead only the charger part works. The installer told me that on my boat it couldn't be hooked up so I can use the outlets and that I have to plug any appliances directly into the inverter (basically running extension cords around) - but that doesn't work either. They installed the inverter in a bin under the settee has no ventilation. They also did not install the fuse between the battery and the inverter as called for in the manual.
So, I'm curious if anyone has experience with this -- I'm not sure what to do next. I'd hate to be ripped off by someone else trying to get this to work... did I just have unrealistic expectations on this?
