HI RICH, SOME OF THE THINGS I'VE...
discovered and repaired include a plugged holding tank vent. Either a critter built a nest in the scupper, or more likely solids backed up into the vent line under pressure. This was an easy fix once I found the problem.The freezer was low on R12 so had it topped off and it runs great. There were five frozen seacocks that the previous owner replaced as a condition of purchase. These need to be worked regularly to keep them clear.The main cabin heat pump compressor froze, so had it replaced. The rest of the stuff was minor, which involved replacing missing screws and bolts, whipping the ends of my lines, installing a line management system that I made, repacking the stuffing box, etc. Right now she is pretty ship shape.You might consider installing a hasp on the two lower transom lockers like I did to keep them from flying open if ever pooped. The instrument panel lights did not work because someone removed the fuse. She is a very comfy boat. We get lots of compliments on how beautiful she looks. She sails easy solo, which I do mostly. My first mate likes to sail when it's flat and no wind. If I think of anything else I'll let you know.Terry
