Converters, inverters, transformers? To answer your question, the converter in your boat is there to convert shorepower, 120V ac power, to 12V dc power to opertae your refrigerator and other 12V fixtures independent of your battery bank. They can also act as a trickle charger for your batteries. The inverter usually does the opposite it converts 12V dc power from your batteries into 120V ac power to operate 120V frixtures. Utilizing a converter requires very little care as the shorepower capacity is considered to be unlimited but the use of an inverter requires careful planning as the capacity of the batteries is limited. A 1 amp/hour draw at 120V becomes a 10 amp/hour draw at 12V and if you add the inneffiency factor of an inverter you are probably looking at a 11.5 amp/hour draw. Inverters are rated in watts and a 100W inverter to run a PC is no great cause for concern but when you run a 3000W inverter to run a coffe maker you better pay attention.
