Hi,
I went to run the microwave oven while at anchor. I started the engine to provide a continuous charge to the batteries. I turned on the Heart 20 (2000 watt) inverter, as well as the microwave switch on the AC panel.
The microwave interior light came on, but not the control panel on the front of it. The control panel comes on when plugged into shore power. I thought I used it underway before, but can't be sure. I also tested the AC plug voltage under the inverter vs shore power. The shore power pegged the needle, and I had to turn the voltage levels down on the tester. The inverter may be on, but just providing an idle charge until being under load, but again, I am not sure. I couldn't get an answer from the owners manual. Any ideas?
Gary
Serenisea2
Gary
Serenisea2
