I just found out that my 1983 Yanmar 2 GM has 2 internal zincs. One in the rear and one on the starboard side behind the diesel oil filter and above the manual lift pump. The starboard zinc needs to be changed. It's attached to a big plug on the block. The PO rounded off the plug but I can still grip it with a socket. The space is limited but I couldn't budge it. I 'm afraid that I'll crack the engine block if I force it.
Any suggestions would be appreciated....
