internal vs. external halyards on C-30
Jim
I'm presently re-rigging my 1976 C-30 and am considering retrofitting the original mast to accomodate internal halyards. This seems to be a relatively inexpensive proposition, but is it worth it and will how well will it work. Has anyone done this and can they give me some advice?
G
Gerry
Internal halyards
Jim, First, you'll have to make sure that your masthead shieves are moved in far enough to not chafe at the mast top opening. Second, is a good location for halyard exit. My C-30 exits just above the mast step thru a shieve then to an organizer mounted on the cabin top near the hand rails. This was a factory set-up on my '84 C-30. Last season we had some kind of friction or snag problem and had a hard time raising the main from the cockpit thru all the turns. Because the halyard exited so close to the deck we had to haul by hand on the cabin top which was bad for my back and my knuckles. So with this in mind I would recommend that you exit your halyard about 3-4 feet above your mast winch, down to a turning block at the mast base, over to an organizer turning it toward a clutch mounted on the cabin top near the cockpit forward of a winch which can be used for the main halyard. If you leave your mast winch in place the you have the option of using it if any problems arise like I had. The same arrangements can be used for the jib halyard. Make sure to file any holes you make to smooth edges, then cap off the exit holes with a s/s trim plate which will help to reduce chafe. I hope this has helped you .
H
Harvey
Why ?
Internal halyards reduce windage, and are out of the way of everything else, but then again if you have to replace any of them external is the way to go. I personaly would not go to the effort to retrofit an older mast.I have been happy that mine are external, at least once.
