Internal Roof Pannels (H-33)
Layla
Aug 5, 2009
3
2 Hunter 33 Herzlia
Hi,
I am new to this forum and appreciate responses. We (three Israeli skiper partners) purchased a new Hunter 33 sailing yacht (Called Layla). We want to add two more Spin-Locks and a Spray-Hood, but we do not know how to take off the internal roof pannels, so we can get to the "Bare" Aluminum plates where we can screw the said devices. Where can we getsuch information? We get no support from the local official importer. Who should I approach at Hunter Marine?
Best Regard
Meir Gerner
Layla
Oct 29, 2005
2,363
Try Al Fooks ( afooks@huntermarine.com ). If its the soft headliner you're planning to remove, let me tell you ..its a pain in the a##. I tried and ended up poking couple of holes and tear and getting no where. Gave up.
Hunter 33 Sold Erie PA
Spin-Locks
Hi I have a 2004 33 and my dealer installed additional spin locks from the top by drilling and tapping the plates and screwing the bolts into them. The job took less than a half hour.
N
nickc
Tap it
Jacksam is spot on. I made the mistake of drilling instead of tapping and then removed the light fitting to get a socket through to hold the nut. Very difficult and ended up with a small tear in the headlining.
Oct 29, 2005
2,363
my winch screw is loosen and I need to tigthen the nut below. that's why I wanted to remove the liners in the 1st place. maybe have to bite the bullet and cut a hole in liner. sharks!!
