Internal halyards
A6C5O7
Oct 8, 2020
19
West Wight Potter 19 Trailer Sailor
I've got a donor mast for a C22 project and it's the same exact extrusion. There was a internal halyard ran with a exit cut but no plate. Wanting to go internal my question is, do you need an exit plate and if so which one would you suggest?
Thank you for any help!
:plus: what Kloudie says. The Schafer design is pretty common. An easy fit into a mast. Be sure you keep the lines inside the mast fair and not twisted as you assemble them.
