H
Howard
When changing the zink in the water jacket on my 1978 8HP yanmar, I stuck my finger in the hole where the plate that holds the zink fits and noticed a sand like substance in the bottom of the water chambor. This is right next to the Kingston Cock, near where the hose from the water pump enters the water jacket. I never did this before, although I change the zink each year. Th 8 HP is raw water cooled. Could this be sand that was sucked into the engine or is it the corsion remains of the old zinks? The sand is soft and can be moved around with my fingure altough I could'd get it out because of the angle.I can't take the side plate off of the motor right now and thought to use a shop vac with a small flexible tube to vac it out? I assume that I should remove the sandy deposites.I never had any problem with overheating or water discharge. Any suggestions ?
