I have a Quick sbc adv charger factory installed in my beneteau. By misstake i switched the poles on the battery and now the charger dont charge. The manual says that there is an internal fuse to protect against short circuit, cant see if its broken or exhange it because its mounted directly on the circuit board.
Anyhow the leds on the charger indicates that everything is fine, so i suspect (hopes) that there is another fuse somewhere on the boat.
My questions are if you know if there is another fuse somewhere and if you have any other ideas that could help me?
Regards
David
Regards
David
