When I flip the toggle switch at the engine panel in the cockpit of my First 310, sometimes I don't get any power (this is like turning the key before pushing the start button). I have removed, cleaned and tightened all the connections to the two batteries, the one black and two red battery switch handles, and all the connections I could find to the starter or engine. The toggle switch is also new. I am at a loss as to what can be causing the problem. I am thinking about having the wiring replaced from the toggle switch to the engine in case there's a bad wire.
Any other ideas? I am quite the non-electrician.
