Intermittent Knot Meter Paddle Wheel Sensor
249
Hunter 36 Newburyport, MA
I just returned from a 5 day cruise up the coast and back. It was delightful except for one thing - every leg had me removing water from my normally dry bilge; accumulated water that gushed in each of the many times I pulled my Raymarine ST60 knotmeter's AirMar sensor to make it spin again, so my wind machine would be able to compute true wind. There was absolutely no seaweed or any other crud visible on the wheel or its shaft, but vigorously spinning the wheel a few times would restore function. Is there some intermittent failure mode with these things? Can some non-visible crud build up around the tiny shaft inside its bearing (a plastic drill hole)? If so, can I use acetone, or some other solvent to dissolve it and keep it clean for longer periods without disolving the plastic housing? My last boat had exactly the same kind of sensor in an ST40, but except for a few seaweed clogs, I had no such trouble. I gather that most instrument manufactirers buy these AirMar sensors, not just Raymarine, so I hope someone has had (and fixed) a similar problem. Thanks.
