Just to let you know, that black rot on the wood near the floor will be a major source of that ever present smell of mildew that you find in neglected boats. Could make you very sick over time. My Vega was especially bad around the fridge where the drain line had become disconnected. I removed the wood and made new pieces. Very easy. If you have rot on the bottom edge of the main bulkheads (under mast support) you need to do that now. You cannot wait to fix that, it supports your mast. From: "bundchen1263@... [AlbinVega]"
AlbinVega@yahoogroups.com To:
AlbinVega@yahoogroups.com Sent: Monday, September 19, 2016 6:43 PM Subject: [AlbinVega] Re: interior work
thank you. i am done with varnishing inside. i used polyurethane minwax brand to match the varnish work done previously. it went on easy and looks ok i guess. there are some water damaged areas which required the wood to be replaced but i cant do that right now. especialy the wood work near the cabin floor turned black probably due to standing water at some point. tomorrow i will start interior paint. sanding is already done i ll put a coat of rustoleum primer and top side paint.
#ygrps-yiv-1156726105 #ygrps-yiv-1156726105yiv1798312533 #ygrps-yiv-1156726105yiv1798312533 --
#ygrps-yiv-1156726105yiv1798312533ygrp-mkp {
border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;}
#ygrps-yiv-1156726105 #ygrps-yiv-1156726105yiv1798312533 #ygrps-yiv-1156726105yiv1798312533ygrp-mkp hr {
border:1px solid #d8d8d8;}
#ygrps-yiv-1156726105 #ygrps-yiv-1156726105yiv1798312533 #ygrps-yiv-1156726105yiv1798312533ygrp-mkp #ygrps-yiv-1156726105yiv1798312533hd {
color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;}
#ygrps-yiv-1156726105 #ygrps-yiv-1156726105yiv1798312533 #ygrps-yiv-1156726105yiv1798312533ygrp-mkp #ygrps-yiv-1156726105yiv1798312533ads {
margin-bottom:10px;}
#ygrps-yiv-1156726105 #ygrps-yiv-1156726105yiv1798312533 #ygrps-yiv-1156726105yiv1798312533ygrp-mkp .ygrps-yiv-1156726105yiv1798312533ad {
padding:0 0;}
#ygrps-yiv-1156726105 #ygrps-yiv-1156726105yiv1798312533 #ygrps-yiv-1156726105yiv1798312533ygrp-mkp .ygrps-yiv-1156726105yiv1798312533ad p {
margin:0;}
#ygrps-yiv-1156726105 #ygrps-yiv-1156726105yiv1798312533 #ygrps-yiv-1156726105yiv1798312533ygrp-mkp .ygrps-yiv-1156726105yiv1798312533ad a {
color:#0000ff;text-decoration:none;}
#ygrps-yiv-1156726105 #ygrps-yiv-1156726105yiv1798312533 #ygrps-yiv-1156726105yiv1798312533ygrp-sponsor #ygrps-yiv-1156726105yiv1798312533ygrp-lc {
font-family:Arial;}
#ygrps-yiv-1156726105 #ygrps-yiv-1156726105yiv1798312533 #ygrps-yiv-1156726105yiv1798312533ygrp-sponsor #ygrps-yiv-1156726105yiv1798312533ygrp-lc #ygrps-yiv-1156726105yiv1798312533hd {
margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;}
#ygrps-yiv-1156726105 #ygrps-yiv-1156726105yiv1798312533 #ygrps-yiv-1156726105yiv1798312533ygrp-sponsor #ygrps-yiv-1156726105yiv1798312533ygrp-lc .ygrps-yiv-1156726105yiv1798312533ad {
margin-bottom:10px;padding:0 0;}
#ygrps-yiv-1156726105 #ygrps-yiv-1156726105yiv1798312533 #ygrps-yiv-1156726105yiv1798312533actions {
font-family:Verdana;font-size:11px;padding:10px 0;}
#ygrps-yiv-1156726105 #ygrps-yiv-1156726105yiv1798312533 #ygrps-yiv-1156726105yiv1798312533activity {
background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;}
#ygrps-yiv-1156726105 #ygrps-yiv-1156726105yiv1798312533 #ygrps-yiv-1156726105yiv1798312533activity span {
font-weight:700;}
#ygrps-yiv-1156726105 #ygrps-yiv-1156726105yiv1798312533 #ygrps-yiv-1156726105yiv1798312533activity span:first-child {
text-transform:uppercase;}
#ygrps-yiv-1156726105 #ygrps-yiv-1156726105yiv1798312533 #ygrps-yiv-1156726105yiv1798312533activity span a {
color:#5085b6;text-decoration:none;}
#ygrps-yiv-1156726105 #ygrps-yiv-1156726105yiv1798312533 #ygrps-yiv-1156726105yiv1798312533activity span span {
color:#ff7900;}
#ygrps-yiv-1156726105 #ygrps-yiv-1156726105yiv1798312533 #ygrps-yiv-1156726105yiv1798312533activity span .ygrps-yiv-1156726105yiv1798312533underline {
text-decoration:underline;}
#ygrps-yiv-1156726105 #ygrps-yiv-1156726105yiv1798312533 .ygrps-yiv-1156726105yiv1798312533attach {
clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;}
#ygrps-yiv-1156726105 #ygrps-yiv-1156726105yiv1798312533 .ygrps-yiv-1156726105yiv1798312533attach div a {
#ygrps-yiv-1156726105 #ygrps-yiv-1156726105yiv1798312533 .ygrps-yiv-1156726105yiv1798312533attach img {
border:none;padding-right:5px;}
#ygrps-yiv-1156726105 #ygrps-yiv-1156726105yiv1798312533 .ygrps-yiv-1156726105yiv1798312533attach label {
display:block;margin-bottom:5px;}
#ygrps-yiv-1156726105 #ygrps-yiv-1156726105yiv1798312533 .ygrps-yiv-1156726105yiv1798312533attach label a {
#ygrps-yiv-1156726105 #ygrps-yiv-1156726105yiv1798312533 blockquote {
margin:0 0 0 4px;}
#ygrps-yiv-1156726105 #ygrps-yiv-1156726105yiv1798312533 .ygrps-yiv-1156726105yiv1798312533bold {
font-family:Arial;font-size:13px;font-weight:700;}
#ygrps-yiv-1156726105 #ygrps-yiv-1156726105yiv1798312533 .ygrps-yiv-1156726105yiv1798312533bold a {
#ygrps-yiv-1156726105 #ygrps-yiv-1156726105yiv1798312533 dd.ygrps-yiv-1156726105yiv1798312533last p a {
font-family:Verdana;font-weight:700;}
#ygrps-yiv-1156726105 #ygrps-yiv-1156726105yiv1798312533 dd.ygrps-yiv-1156726105yiv1798312533last p span {
margin-right:10px;font-family:Verdana;font-weight:700;}
#ygrps-yiv-1156726105 #ygrps-yiv-1156726105yiv1798312533 dd.ygrps-yiv-1156726105yiv1798312533last p span.ygrps-yiv-1156726105yiv1798312533yshortcuts {
margin-right:0;}
#ygrps-yiv-1156726105 #ygrps-yiv-1156726105yiv1798312533 div.ygrps-yiv-1156726105yiv1798312533attach-table div div a {
#ygrps-yiv-1156726105 #ygrps-yiv-1156726105yiv1798312533 div.ygrps-yiv-1156726105yiv1798312533attach-table {
width:400px;}
#ygrps-yiv-1156726105 #ygrps-yiv-1156726105yiv1798312533 div.ygrps-yiv-1156726105yiv1798312533file-title a, #ygrps-yiv-1156726105 #ygrps-yiv-1156726105yiv1798312533 div.ygrps-yiv-1156726105yiv1798312533file-title a:active, #ygrps-yiv-1156726105 #ygrps-yiv-1156726105yiv1798312533 div.ygrps-yiv-1156726105yiv1798312533file-title a:hover, #ygrps-yiv-1156726105 #ygrps-yiv-1156726105yiv1798312533 div.ygrps-yiv-1156726105yiv1798312533file-title a:visited {
#ygrps-yiv-1156726105 #ygrps-yiv-1156726105yiv1798312533 div.ygrps-yiv-1156726105yiv1798312533photo-title a, #ygrps-yiv-1156726105 #ygrps-yiv-1156726105yiv1798312533 div.ygrps-yiv-1156726105yiv1798312533photo-title a:active, #ygrps-yiv-1156726105 #ygrps-yiv-1156726105yiv1798312533 div.ygrps-yiv-1156726105yiv1798312533photo-title a:hover, #ygrps-yiv-1156726105 #ygrps-yiv-1156726105yiv1798312533 div.ygrps-yiv-1156726105yiv1798312533photo-title a:visited {
#ygrps-yiv-1156726105 #ygrps-yiv-1156726105yiv1798312533 div#ygrps-yiv-1156726105yiv1798312533ygrp-mlmsg #ygrps-yiv-1156726105yiv1798312533ygrp-msg p a span.ygrps-yiv-1156726105yiv1798312533yshortcuts {
font-family:Verdana;font-size:10px;font-weight:normal;}
#ygrps-yiv-1156726105 #ygrps-yiv-1156726105yiv1798312533 .ygrps-yiv-1156726105yiv1798312533green {
color:#628c2a;}
#ygrps-yiv-1156726105 #ygrps-yiv-1156726105yiv1798312533 .ygrps-yiv-1156726105yiv1798312533MsoNormal {
margin:0 0 0 0;}
#ygrps-yiv-1156726105 #ygrps-yiv-1156726105yiv1798312533 o {
font-size:0;}
#ygrps-yiv-1156726105 #ygrps-yiv-1156726105yiv1798312533 #ygrps-yiv-1156726105yiv1798312533photos div {
float:left;width:72px;}
#ygrps-yiv-1156726105 #ygrps-yiv-1156726105yiv1798312533 #ygrps-yiv-1156726105yiv1798312533photos div div {
border:1px solid #666666;min-height:62px;overflow:hidden;width:62px;}
#ygrps-yiv-1156726105 #ygrps-yiv-1156726105yiv1798312533 #ygrps-yiv-1156726105yiv1798312533photos div label {
color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;}
#ygrps-yiv-1156726105 #ygrps-yiv-1156726105yiv1798312533 #ygrps-yiv-1156726105yiv1798312533reco-category {
font-size:77%;}
#ygrps-yiv-1156726105 #ygrps-yiv-1156726105yiv1798312533 #ygrps-yiv-1156726105yiv1798312533reco-desc {
font-size:77%;}
#ygrps-yiv-1156726105 #ygrps-yiv-1156726105yiv1798312533 .ygrps-yiv-1156726105yiv1798312533replbq {
margin:4px;}
#ygrps-yiv-1156726105 #ygrps-yiv-1156726105yiv1798312533 #ygrps-yiv-1156726105yiv1798312533ygrp-actbar div a:first-child {
margin-right:2px;padding-right:5px;}
#ygrps-yiv-1156726105 #ygrps-yiv-1156726105yiv1798312533 #ygrps-yiv-1156726105yiv1798312533ygrp-mlmsg {
font-size:13px;font-family:Arial, helvetica, clean, sans-serif;}
#ygrps-yiv-1156726105 #ygrps-yiv-1156726105yiv1798312533 #ygrps-yiv-1156726105yiv1798312533ygrp-mlmsg table {
font-size:inherit;font:100%;}
#ygrps-yiv-1156726105 #ygrps-yiv-1156726105yiv1798312533 #ygrps-yiv-1156726105yiv1798312533ygrp-mlmsg select, #ygrps-yiv-1156726105 #ygrps-yiv-1156726105yiv1798312533 input, #ygrps-yiv-1156726105 #ygrps-yiv-1156726105yiv1798312533 textarea {
font:99% Arial, Helvetica, clean, sans-serif;}
#ygrps-yiv-1156726105 #ygrps-yiv-1156726105yiv1798312533 #ygrps-yiv-1156726105yiv1798312533ygrp-mlmsg pre, #ygrps-yiv-1156726105 #ygrps-yiv-1156726105yiv1798312533 code {
font:115% monospace;}
#ygrps-yiv-1156726105 #ygrps-yiv-1156726105yiv1798312533 #ygrps-yiv-1156726105yiv1798312533ygrp-mlmsg * {
line-height:1.22em;}
#ygrps-yiv-1156726105 #ygrps-yiv-1156726105yiv1798312533 #ygrps-yiv-1156726105yiv1798312533ygrp-mlmsg #ygrps-yiv-1156726105yiv1798312533logo {
padding-bottom:10px;}#ygrps-yiv-1156726105 #ygrps-yiv-1156726105yiv1798312533 #ygrps-yiv-1156726105yiv1798312533ygrp-msg p a {
font-family:Verdana;}
#ygrps-yiv-1156726105 #ygrps-yiv-1156726105yiv1798312533 #ygrps-yiv-1156726105yiv1798312533ygrp-msg p#ygrps-yiv-1156726105yiv1798312533attach-count span {
color:#1E66AE;font-weight:700;}
#ygrps-yiv-1156726105 #ygrps-yiv-1156726105yiv1798312533 #ygrps-yiv-1156726105yiv1798312533ygrp-reco #ygrps-yiv-1156726105yiv1798312533reco-head {
color:#ff7900;font-weight:700;}
#ygrps-yiv-1156726105 #ygrps-yiv-1156726105yiv1798312533 #ygrps-yiv-1156726105yiv1798312533ygrp-reco {
margin-bottom:20px;padding:0px;}
#ygrps-yiv-1156726105 #ygrps-yiv-1156726105yiv1798312533 #ygrps-yiv-1156726105yiv1798312533ygrp-sponsor #ygrps-yiv-1156726105yiv1798312533ov li a {
font-size:130%;text-decoration:none;}
#ygrps-yiv-1156726105 #ygrps-yiv-1156726105yiv1798312533 #ygrps-yiv-1156726105yiv1798312533ygrp-sponsor #ygrps-yiv-1156726105yiv1798312533ov li {
font-size:77%;list-style-type:square;padding:6px 0;}
#ygrps-yiv-1156726105 #ygrps-yiv-1156726105yiv1798312533 #ygrps-yiv-1156726105yiv1798312533ygrp-sponsor #ygrps-yiv-1156726105yiv1798312533ov ul {
margin:0;padding:0 0 0 8px;}
#ygrps-yiv-1156726105 #ygrps-yiv-1156726105yiv1798312533 #ygrps-yiv-1156726105yiv1798312533ygrp-text {
font-family:Georgia;}
#ygrps-yiv-1156726105 #ygrps-yiv-1156726105yiv1798312533 #ygrps-yiv-1156726105yiv1798312533ygrp-text p {
margin:0 0 1em 0;}
#ygrps-yiv-1156726105 #ygrps-yiv-1156726105yiv1798312533 #ygrps-yiv-1156726105yiv1798312533ygrp-text tt {
font-size:120%;}
#ygrps-yiv-1156726105 #ygrps-yiv-1156726105yiv1798312533 #ygrps-yiv-1156726105yiv1798312533ygrp-vital ul li:last-child {
border-right:none !important;}
