Interior wood touch up - what stain was used
1,742
Bristol 29.9 Dana Point
Am looking at refinishing some areas of interior wood. Head sink trim is faded, probably from sink water, and other interior areas a little faded from sun. Have no intention of varnishing.
Does anyone know what stain\finish was used (if any) on Catalina yachts in the early 90's?
-or-
How would you bring back the original color?
zeehag
Mar 26, 2009
3,198
-or-
try teak oil--get it at home depot--is less expensive for the same stuff...
Oct 9, 2008
1,742
Thanks, but I use teak oil annually already. Doesnt do anything for the finish, it's still faded.
Jan 3, 2009
821
Marine Trader 34 Where Ever I am
Skipper, A lot of these stains, etc. were custom made for the manufacturers. I would suggest you remove a piece of wood and take it to the hardware store to match. Even then you will want to experiment with a piece of wood before applying it in the cabin. We have found teak stain that matches some quite nicely and Colonial Maple that works well in other areas. Chuck
Oct 9, 2008
1,742
H&L Marine
Thanks for advice.
I have called and sent an email to H&L Marine, the interior cabinetry manufacturer for Catalina. No response yet. I'll contact Catalina too.
The difference is that on a good sailing forum, I can get great advice in a matter of minutes. (Contacting manufacturers is unpredicatable.) and was hoping that someone here also had faded interior wood on their boat and knew what stain was originally used or had found an alternate remedy.
Jul 25, 2009
270
Catalina 1989 C30 Mk II Herrington Harbour South, MD
Then try this: http://c34.org/bbs/index.php/topic,1108.0.html
Also, one of these days folks will begin to understand that the telephone still exists and will stop getting frustrated when their emails don't get answered.
Not YOU, because you did call, but many other don't.
Except that any supplier who gives multiple points of contact absolutely must answer them. If you don't want to correspond with your clients via email, then don't have an email address. As a supplier, dealer, or service shop, your job is to make your customers' lives easier, if you can't do that as part of your set of core competencies, then you don't deserve to stay in business. Rig-rite, I am looking at you, here.
Ross
Jun 15, 2004
14,693
When I need to absolutely match a stain I go to a local artist's supply store and buy some oil paint pigments. Each is a true color. I then blend them on a sheet of glass to get the color I need and work from there. I use glass because they won't soak into the glass as they might/will with wood.
Jun 16, 2009
32
Hunter 30 Behind the house...
wood stains are fairly easily mixed and matched
you have to make sure that they have the same base (water or spirituous) and then mix away
you could try for color on a sheet of teak laminate since that would be a lot cheaper then hardwood mark your mixing rate, then when you feel you have an approximate finish oil the surface (or spit on it) and compare the colors to the one in your cabin
I did this several times with a lot of different mixtures lined up next to each other the more defined your pallet the truer your mix
good luck
llvan
Jan 25, 2010
1
Hunter 1987 Lake Travis
Polyshade Natural Cherry carried by Ace Hardware. $14 online. A definate match. I used it on my Catalina 27 and it was a perfect match.
Ross
Jun 15, 2004
14,693
Polyshades is a urethane varnish type finish. Oil pigments and Watco teak oiul will serve just fine.
Jul 3, 2004
8
- - kansas
Constantines in Ft Lauderdale have been serving the carpentry and furniture refinishing trades for many years. I'm a bit out of touch with them, but back when I did this stuff, they had a great catalog, with some guidance included.
On pre-finished wood, such as you have, I'd probably rub it down carefully with 0000 steel wool, then blend in some color using an alcohol stain, so as to penetrate the surface and not raise the wood grain.
When the color is right, they have padding lacquers you can use to seal in the new stain, and then you can refinish with whatever surface finish that, er....floats your boat! 8^).
www.constantines.com is the place to start. Dennis Martin
I would strongly urge you to never use steel wool on a boat. Bronze wool is fine. Steel rusts.
Cherubini 37c HULL#37 Alameda
I used steel wool once to clean rust off my life lines. Ill never do that again. A year later I'm still finding rust spots on the deck from the wool that are near impossible to remove.
Nov 8, 2009
537
Hunter 386LE San Fancisco
Consider lightly sanding and varnishing the interior walls. Key is to color match the interior. Some older sailboats may have a combination of cetol, teak oil and varnish on them. That requires stripping, sanding, bleaching, sealing and varnishing them. Since you do not want to varnish the interior consider a home cabinet refinisher who does not strip or varnish. I used one on my home cabinets several years ago. They are very low cost, fast (< 1 day), looks great, removes water damage and lasts 10+ years.
Oct 22, 2008
3,502
- Telstar 28 Buzzards Bay
Instead of using steel wool, bronze wool or scotch brite pads are far better choices... no rust pox from the tiny piece of steel shedding...
maxxx
Oct 15, 2009
60
oday 28 Ft. Loudon lake
I'm about to reoil the interior of my oday28 and am going to try Watco. Anybody had any experiance with it???
Ross
Jun 15, 2004
14,693
I have been using the watco oil for many years starting back when it was called Varithane penetrating oil/sealer. Follow the directions. DON'T leave any puddles! You can use it as you wet sand with very fine sand paper.
Steel wool has no place on a boat or on oak that may get wet. You will get iron staining.
Edit to add: Dispose of the rags outside, spread out, to dry and do not wad them up and toss them into a corner. They will catch fire spontaneously .
