Interior wood on 1984 Hunter 31
IanJ
Nov 7, 2008
152
Hunter 31 Port Royal, CA
I need to do some sanding and re staining of some of my water damaged wood finish in my 1984 Hunter 31. Before I start sanding, anyone any idea what wood this is? I cannot believe it is real teak. Can one sand and then varnish to retain the original color, or does it have to be stained? Any info much appreciated
Mark48
Mar 1, 2008
166
Hunter 34 Milwaukee
Unless you sand down the entire piece you will remove the patina from the sanded area and will need to try and match the unsanded wood with stain. Our 85 Hunter is mostly a rubbed oil finish. I use lemon oil to keep it looking fresh.
Nov 6, 2006
10,104
Wood is mostly a thin veneer over plywood.. Finish was stain/oiled .. Sanding is very risky because you can go through the veneer very easily. Best to clean and re-oil..
Dec 2, 1999
15,184
The interior wood is teak but like Kloudie mentioned it is veneer.
The finish is normally Daly's Seafin but it could have been redone with anything after all these years.
IanJ
Nov 7, 2008
152
Thanks guys. Unfortunately got a little water damage under one port, so will tread carefully!
