Paul McKune
Seems like our boat is a 21 footer, did not see it listed. We have a v-berth in which the porta-head is also located. This is separated from the main cabin by a wooden bulkhead. The bulkhead is thin sheet inserted in channel that is molded in the fiberglas overhead and a vertical piece of wooden c-channel to which the folding door is attached. The port and starboard stays are attached to the deck with through-bolts that also attach to brackets that are fastened to the wooden bulkhead. We want to modify the cabin by removing the bulkhead. Our question is, is the vertical piece of wooden channel a structural component or not. I believe it is not and that all the structural integrity is found in the molded fiberglass cabin shape. A kind of "eggshell" effect. I believe we can remove the wood, install a flat plate on the interior side of the stay through bolts to distribute the pull-out force applied to the deck and have a much more open cabin with no compromise of our structural integrity. Can anyone weigh in on this? Thanks
