Interesting Foil Concept....
5,274
Yeah, that is interesting. So what is the purpose? They don't discuss that. Must be 'secret'. LOL
But to have a horizontal wing on the leeward side I guess would keep the boat flat on the water. I don't know. I am not a yacht designer or naval architect.
Gunni
Mar 16, 2010
5,937
A retractable horizontal stabilizer located in a trunk below the waterline? What could go wrong with that? !:)!
Nov 6, 2006
10,217
I'm with you, Gunni.. Looks like an efficient crab pot collector ! and then there was the unmarked piling right at waterline .. Seems kinda strange to have a boat limited to only open ocean..
Constantly submerged hydraulics or electric actuators.. Uhhhh-- Yeah
RichH
Feb 14, 2005
4,773
Very novel !!!
Dynamic stability increases with faster speeds through the water and would most certainly retard and dampen the rolling period. Such could also have automatic control surfaces and pitch angles similar to the current International moth 'foiler'. http://www.youtube.com/watch?v=IcOzUn3-mrI ..... that little 'black whisker' hanging down from near the tip of the bow at 1 min. 50 seconds into the video is the 'control rod sensor' for the automatic hydrofoil 'pitch control'.
However, an additional 'daggerboard' etc. far enough away from the keel or CB foil and located in 'undisturbed flow' would do the exact same thing as regards 'stability' .... tried even on Americas Cup boats (Tom Blackaller ~1987) with quite poor results as the increase of drag affected speed.
The more modern trend is to build wider beam boats with very flat bottoms for the exact same dynamic stability effect.
The super fast ILYA scows (normal speed @ 15-25 kts), with retractable twin 'bilge boards' (2 centerboards each located near the hull sides and set at a slight offset angle from the vertical) have been doing this since the 1890s !!! The 'windward' board is usually retracted when sailing due to the excess drag the second board causes.
http://www.youtube.com/watch?v=zEnMGV1TfkQ
http://www.melges.com/boat.php?p=pages/boats/A-scow
