A Clue-I dont own one yet but this may help
Boats built since spring 1999 have a new deck structure. Older boats have a balsa-cored deck and companionway hatch. The new deck is stiffened by a series of solid fiberglass U-shaped beams with an outer flange bonded to the inside of the deck. The beams, which are on 4"-6" centers, are filled with foam, over which are laid layers of 1.5-oz. mat; the deck liner is then laid over the deck, which compresses the foam and bonds the deck and liner. MacGregor said the new method produces a stronger structure and avoids the problems of rot with balsa. The process also reduces weight by 125 lbs. Water ballast is carried in a chamber that runs from 3' forward of the transom to the V-berth; it is 4' wide and acts as a longitudinal stringer. It is enclosed by a fiberglass module bonded to the hull. This leaves precious little area below the sole for a bilge. Because there is no way to inspect the bilge without looking behind the galley, there is no way of knowing how much water is in it. The company now drills a 1/2" hole in the sole below the companionway to allow bilge water to appear on the floor of the main cabin. “Without the hole it is possible for the boat to collect a really large, stability-threatening load of bilge water,” MacGregor said. “Since the liner floor area is essentially a watertight tub, the skipper had no way of knowing until it reached the level of the cutout in the face of the galley.” “I prefer a more obvious warning. When he steps in the cabin and ends up with water up to his ankles he will get the message. I recommend owners of older boats make a similar hole,” being careful not to drill into the water tank. One owner said cleaning up bilge water on the sole is messy.
