A
Andrew Wilkins
I have just installed an Adler/Barbour ColdMachine in my 1995 Hunter 29.5, and on inspection found the icebox has only about 2 inches of insulation around it. Without having to dismantle the galley area, has anyone been able to use the expanding foam insulation in the spaces between the icebox insulation and the hull, under the sink locker, and both ends. I am thinking of drilling holes in the wells at the back of the icebox and filling with foam insulation, then the sides and front. Filling the areas from the bottom of the icebox exterior to the top. The holes will be plugged with gelcoat/epoxy and teak plugs to complete the installation. Anyway, if someone has attempted this or has a more successful method, I would be please to try it.
