Just got back from a 2 week vacation at Cuttyhunk and Martha’s Vineyard. Vacation was great but had some trouble with the instruments in the lower NavPod at the end.
The tachometer began acting strangely going all the way to max and then back, but averaging significantly higher than usual.
Volt meter would register 12 then suddenly switch to 11.5 and the blower would slightly decrease at the same time, then after a period of time it would return to 12. This happens without any change to the engine speed. Now the Volt Meter is registering only 10.5. The volt meter on the panel inside the boat , however, was reading between 13 and 14 and the batteries are being charged fine.
One morning I turned the key and nothing. None of the instruments were on and start button would not respond. I checked everything, tried a few times, then hit the NavPod a couple of times with my fist. (The admiral thought I had lost it) Suddenly everything came on. Engine started. We motored out of the harbor fine. Then everything on the panel shut off. The engine was still running fine, so we got to the next harbor.
The next day the engine started fine.
I opened up the NavPod and could not find any loose wire, but was not able to spend a lot of time going into detail with each wire. I was happy to see the inside of the NavPod look almost as good as new even though the boat is a 2004.
If anyone has any ideas, I would appreciate it.
