Installing Wind Instruments
21
Beneteau oceans 321 Saint John
We have a 1997 Beneteau 321 .Looking for advice suggestions installing a
Mast top wind transmitter ,cabling- Conventional mast not roller furling
Jan 4, 2006
7,064
It's Doubtful .......................................
................... you'll be able to tell exactly what the mast head looks like from research or from the ground. I had no luck in finding out what mine looked like and the boat was only a year old.
When I did my '99 hunter 310, I took the trip to the top with a camera (it was all film then) and photoed it from every angle and then fabricated a small footing to hold the sensor. While you're up there, you'll also be able to see if there are any tracers to fish your cables down the mast. If not, a string with a few nuts on it is a good way to get a tracer down the mast.
If you like a challenge, go up on a cold and windy day as it's an experience you won't soon forget. I still can't forget and it's been twelve years :eek:.
If you're smart, save it for a warm and calm day and it's actually a lot of fun.
Nov 8, 2010
11,386
Some thoughts.
Re the actual device, I'd match brands with your existing instruments. Raymarine? You will need to get boat speed into the wind instrument if you want to monitor true wind, which is 90% of the value of the thing. Otherwise its just a remote (and expensive) windex.
If they both support NMEA0183 or NMEA2000, you can mix and match.
In your mast should be a cable conduit, with a mouse line to pull more cables. I'd really recommend you run the cable in here, or it will clang as the long heavy cable slaps inside the mast. To do this you will have to pull the masthead off. I don't know of any other way to do it.
You boat probably has a USspars/Zspars mast. USspars has a web site that shows your mast and mast head. On a masthead rig like yours the masthead is normally large. You should have plenty of room.
Jun 9, 2008
1,780
- -- -Bayfield
You have to get at your masthead to see what sort of surfaces are on top for mounting the bracket for your masthead unit. Usually there is a spot to do so. Make sure you look in the manual first to determine if the masthead unit is supposed to face forward or aft. That makes a difference and you don't want to install it facing it the wrong way. The cable is then usually run through a hole you drill on one side of the mast and it runs down the whole length of the mast to the bottom. If your mast is deck stepped, then you have to see how the other electrical (light?) cables run through the deck and do it in a similar matter. If the mast is keel stepped, then you have to see how the wires run out of the base of the mast and do it in a similar fashion. Getting the wire through your mast might have to be done by fishing a fish tape wire through first and then pulling it through. If you have a tube inside the mast to contain wires, then you can run it through it, if there is enough room left. Otherwise, just down the center of the mast and try not to twist it around halyards that might be inside. pull them tight and you should do ok. Where ever the mast sits on the deck or keel step, you will then make a junction box (which might come with the unit) where you can cut the wires and then attach them to a barrier strip so that when you take the mast down you can disconnect the wires there, rather than running the whole cable to the instrument itself. Then you must run the 2nd (now spliced) wire to the instrument head, finding a way to run it through the bilge, or under a berth, etc. to hide the wires to the unit. Again, a fish tape will help you route the cable where you cannot feed it by hand. If you have not bought the instruments yet and you have decided to not go through all of this work, then find a company that sells wireless instruments. You just have to the install the masthead unit and instrument head and there are no wires to run. Pretty quick and easy. Tack Tick is one of such companies who offer that.
AndyS
Sep 26, 2009
15
Beneteau 281 River Dunes, NC
I went with the TackTick wireless wind instruments on my 281 and have been very satisfied. For the past three seasons the combination of the solar powered mast unit and the solar powered display have worked flawlessly together. Mounting the unit to the top of the mast was relatively easy, as there was a good spot to attach it to. In fact, it survived a direct hit by Hurricane Irene last fall. I went with TackTick because of the ease of installation and the lack of wiring. Nothing beats a good hard-wired system, especially when you can interface it with your boat's speed, but the TackTick system is a good system when you want to quickly mount something on the mast, and you have the option of moving the display unit around the boat (i.e., I have a separate mount in the cabin so that at night I can see the wind speed). Just my two cents.
