I am replacing a standard winch with a self tailing one. This winch is for my in-mast furler.What bedding compound should I use? The Lewmar site has the following instructions--- 5 x M6 (1/4 in) c’sk head screws on 94mm (3 11/16 in) PCD---- concerning the mounting bolts. I assumed that the winch would come with bolts but I was wrong. What kind of head is a c'sk and what would you guess that PCD stands for.Although this winch is a # 14 and the existing one is a #8, the bases are nearly the same diameter so maybe I can use the bolts from my old winch.Any advice will be welcome.Bill
