Sealant for installing Teak/Holly
I would suggest Life Seal, since the plywood will be encased in epoxy. If it were not encased, I would suggest Teak Deck Sealant, which requires no primer and also has a 24 hour cure time.Life Seal is a silicone/polyurethane combination which takes the best features of each and none of the drawbacks of either.24 hour curing, permanently flexible, superior UV, low odor, non-acid curing, mildew resistant and it can be removed without damaging the surface.
