Finishing Teak Handrails
Eric,I'll share my experience with teak finishes and echo Mike Branford's comments. Not impressed with the longevity of teak oil treatments but they are easy to apply. Have used Interlux varnish on my 272, think six coats the first year (follow directions about thinning the first coat to seal the wood) and then a couple of coats each spring and fall thereafter. Most varnishes must dry for at least 8 hours and you have to sand between coats which is very time consuming. The bottom line for me is the process is time consuming, the finish is beautiful, you can easily repair a spot, but you must keep up the annual maintenance-if you let it go you have to scrape all the finish off and start all over. Tried Bristol Finish this year which allows new coat after two hours and no sanding. I never could get on more than two coats in a day and didn't feel it lived up to to its billing (that's my opinion, Practical Sailor liked it a lot and that's why I tried it). It is more expensive than varish or oil. Be real careful when mixing the two parts, it must be done exactly just like epoxy. Went to Epiphanes varish this year and like it. Agree with Mike's comments about Cetol, but I am going to use the new Cetol products on my new motor boat. It has to much wood for me to commit to the annual varnish regime; I'm hoping to only recoat every few years. You put on a couple of coats of the stain (which is not as orangey as the original Cetol) and then follow with coats of a gloss clear coat which is supposed to make it look more like varnish and add depth tot he finish. Won't be doing this until next spring, but I'm making the commitment to the new Cetol products.Good luck with the new rails.Frank
