Installing Solar Panel system
Ron M
I need some help from anyone who's installed a PV system on their Hunter 386 (or similar). I recently purchased a Kyocera 130 Watt panel, a Xantrex C35 charge controller w/ battery temp sensing module. The PV will be mounted over the bimini. I plan on using 8 AWG two wire (red/yellow) since the PV to controller is approx. 25 ft. I understand I need a breaker between the PV and the charger. What make/model breaker/box should I get (I believe a 15 amp is adequate) and where on the boat should it be installed? Do I need to install another breaker between the controller and the battery switch? That distance is only about 2 ft. Any diagrams or suggestions would be appreciated.
Dec 2, 1999
15,184
Check out the Blue Sea website
Ron: Check out the Blue Sea website. They have some of the best equipment for these types of installations. I think that you can also contact them via phone or email for tech. advise.
