installing refridgeration in a Hunter Legend 37
W
Wilf from Winnipeg
I have purchased a Novacool unit to convert the icebox on my 1987 Legend 37 to refridgeration, but I have a few nagging questions that I need to know prior to installing: 1. I understand that the compressor is to be installed UNDER the bottom shelf, beneath the galley sink on the port side, however I don't see how I can mount it without building another shelf, and I am not sure of the best orientation, ie. fan facing to port or towards the bow? 2. Where do I run the lines from the compressor, a helpful Hunter owner Paul Akers suggested through the partition under the stove, but I am not sure if he meant UNDER the stove in the space between the stove and the top of the cabinet, or right underneath this, on the top shelf in the cabinet under the stove? 3. The odd shape of the icebox has me (and others) wondering where the best place to put the actual icebox in the cooler to minimize lines running through, and allowing access to the icebox (due to the overhangs from the counter)? 4. Where is the best place to instal the therhermostat? On the inside or outside the fridge, and where? 5. How and where do you run the electrical wiring? Is 10 guage large enough? How many feet are needed? Thank you in advance if you can shed any light on my installation. Wilf
Paul Akers
I'll check...
I'll try to check these questions when I get to the boat this weekend.
Paul Akers
Contact me...
Wilf, contact me through the Owner's Forum. I checked it out this weekend and I have some answers.
