Some thoughts to keep in mind. Put the radar up the mast where you have the afore mentioned issues, or a pole mount which hasnt been really talked about. The mast mount is neater, cleaner, and way more difficult to deal with if you have maintenance issues. Not to mention installation. Next, what is the scope of what you want your radar to do. Do you want to navigate in fog on the way back to the slip, cross some shipping lanes, or do you want to see a hundred targets that appear and then dont on the next scan. A 2k scanner will only have the ability to paint a sailboat size target, if sea and weather permits, out to about 6 miles. It will paint a cruise ship farther, maybe 10-12 miles tops. Its the power (of the radar) that is available. A 4k can do better but you need a significant amount of amp hours... but why. Not very practical on a sailboat. Whether you do a pole mount at about 8-10 feet on your stern or a mast mount, you are not really buying yourself that much (curvature of the earth). Also remember the higher up the mast, assuming your not doing a gimbal mount, the more beam errors do to angles created by pitch and roll, hence a very difficult to read radar presentation. IMHO, you need to know what is inside of 3-5 miles, and no sh*t what is inside 2 when it comes to traffic. You will be able to interpret the picture more easily. Breaking out a jetty at sailboat speeds , or bouys... well it doesnt matter if the scanner is sitting on the foredeck! You can read the picture.
Just food for thought
Cheers
