Installing tracks
I installed 4 ft long tracks last year on my trusty H23. It wasn't hard, but it was time consuming. Here's the process in a nutshell:a) Tape the track securely to the deckb) mark all the holes, including a hole at each end for the track end-stop.c) drill the holes. If your deck is cored, drill the holes at least 1/4-inch larger than the diameter of the fasteners you will use to bolt the track downd) seal the holes from underneath with a dab of caulk. Don't overdo it. Tape won't work (I have cured epoxy drips in my carpeting overhead to prove it)e) when the caulk has cured (at least 24 hr later, fill the holes with epoxy from above. This will seal the wood core of your deck from water in case the future caulking ever fails. West System or Epiglass is best. You want to give the epoxy some time to soak into the wood. Do't be surprised if you have to top up some of the holes before the epoxy begins to setf) When the epoxy has cured, retape the track to the deck and drill small pilot holes, then remove track and finish drilling holes all the way through. Do NOT through-drill the holes for the track end-stops.g) Clean up drilling mess, mask off deck next to track, mask off the entire track except for the mounting surface underneath and the holes on top for the bolts. Mask off track end-stops.h) lay beads of your favorite caulk on deck around mounting holes. I used LifeCaulk simply because I had a lot of it laying around. 3M 5200 is probably better because the track is not going to move. Push the bolts in. Tighten the nuts finger-tight. i) have a cold beer (you earned it!)j) when caulk gets tacky, remove masking tape. If you do this right you will have NOTHING else to clean upk) when the caulk has cured, tighten nuts uniformly to compress caulk.l) fasten track end stops to deck with self-tapping screws in pilot holes. This will allow you to replace end-stops single-handed in less than ten minutes when they break in the future.m) go sailingPeterH23 "Raven"
