Installing holding tank on Oday 25
C
Carole Lockhart
I have recently purchases a 25 ft Oday (1976). It appears that there never was a holding tank and that the head waste is discharged directly out of the boat. I want to add a holding tank with a Y connection. Is there a "typical" location on the 25 ft Oday for the holding tank?
Jim A
I wouldn't
they are a pain in the neck. Dump overboard baby, don't worry about the darn swimmers. Seriously I would recommend a bladder system or better yet a plain old fashion port-a-pot! Yes, port-a-pot is the way to go... You don't have to change it. You have to secure the head. Locking the door is adaquate so the head can't be used.
Peggie Hall/HeadMistress
On a boat that size, you may be better off with
a permanently installed, fitted for pumpout, portapotty. 'Cuz if the toilet is still original, it has to be worn out by now--or so obsolete you can't even get a rebuild kit for it any more. The cheapest toilets don't even have to be that old. And a holding tank big enough to be worth the effort and expense to install will use up a lot of storage space...because of the difference in the amount of flush water used a by a manual toilet, you'd need at least a 15-18 gallon tank to provide any noticeable advantage over the number of flushes a 5-6 gallon "pumpable" portapotty holds. My choice would be the SeaLand 965-MSD. No plumbing required except pumpout line and vent to the outside of the boat. You already have a discharge thru-hull, so if you want to be able to dump it at sea, you'd only have to install a y-valve in the pumpout line, with one side going to a pump and that thru-hull. A clean neat, self-contained installation that offers all the advantages of a marine toilet and holding tank, but with none of the plumbing and maintenance they require.
C
Carole Lockhart
Something to think about
The feedback was not what I anticipated - but gives me some options I had not considered. Thanks.
When you decide which way you want to go,
Get back to us and I'll be glad to help you spec out the details.
