installing heat and ac
L
lynndon
we are in the process of purchasing a hunter 34' would like to get an idea of the cost and experience of someone who has added heat and ac to their sailboat. pitfalls, problems and are u satisfied.
John Kudera
Heat and AC
I did that job last spring, we are definately very happy with both the heat and AC. A bit noisier than we thought, but you get accoustomed to the noise, and sleep without a problem. My cost was under $2000, but the installation is not a weekend job, expect 30 to 35 hours work, and be advised you need to know the basics of carpentry, plumbing and HVAC. Our boat is in NJ and I will meet you and show you my installation if you wish, just E mail me separately.Best of luck on the H34 purchase and your installation!
G
Gene Gruender
PVC ducting
When we put the ac/heat in Rainbow Chaser, out Hunter 37 Cutter, we weren't real happy with the duct kits we saw. Instead, we used PVC pipes for ducts. I sawed a 6" elbow to fit the output, then used normal fittings to make the ducts. You can also use a heat gun to bend the pipes or make it custom. My concern was that we would have condensation dripping off the plastic, but I've discovered that if the pipes are run in the same area that is cooled, it isn't a problem at all. Since any duct is inside the boat, there has never been a drop. The advantages are, 1. it's much cheaper, and, 2. they are much more durable.
C
Clyde Lichtenwalner
HVAC
We installed HVAC two years ago on our H-34. It was worth the trouble. We use the boat more and in an entirely different manner. I did the work myself, and it cost about $2k. Of course, you will pay more if others do the engineering and installation. It will require 12 to 16 thousand BTUs depending on where your boat will be located. If your are staying in the Hudson valley 12k will do the job. For the Chesapeake south, 16k is better. On any boat there is a problem with distribution of the air. Ductwork takes up storage space. I have chosen to install a 12,000 BTU unit in the aft cabin. I plan to add a 5,000 BTU unit in the forward cabin. No ductwork running the length of the boat is necessary. The two units may be run independently and they take up less space than one centrally located unit with ductwork. I have lost no storage space in the aft area of the boat, and when completed, little in the forward. Of course it requires two of everything, but you can run the smaller unit on an inverter. Air while motoring, or from a 1000 W Honda generator. 5000 BTUs is better than nothing on a hot, humid, rainy day. The single 12k unit has been serving us well for the last 2 years with fans helping to circulate the air to the forward cabin. It will be better when the front unit is also installed. Other locations for single units include under the chart table, and next to the water heater, both with duct work running forward and aft to serve the ends of the boat. I have also seen a unit mounted above the port setee.
A
Aldo Lozano
To John Kudera
John, I think U forgot to put Ur e-mail in Ur answer... I have a Hun27/83 and I will like to see Ur installation and/or get details about it.Do U need 120 Volts AC to run it? I think I am about one hour drive from Ur place.My e-mail address is alozano@monmouth.com Thanks for Ur attention!
