Installing Halyard Restrainer
Mike48
Mar 15, 2006
35
Hunter 23 Lake St Marys
I'm installing a halyard restrainer that came with my Schaefer CF-500 roller furler. There is one hole on each side. What would be stronger: a 3/16 stainless pop rivet or drill and tap for a #10 machine screw?
Thanks,
Mike
Nov 8, 2010
11,386
Rivets. Technically for that load (tension) rivets will be better anyway. Tapped properly, screws are better in shear. But your mast section is so thin that even with a fine pitch you will not get much bite.
For the average Joe working on his own boat, rivets are much easier to do a good job with, and the difference in strength is minimal in any case.
Apr 27, 2010
1,279
Hunter 23 Lake Wallenpaupack
Jack, for that kind of use, or say riveting the fitting to the bottom of a mast extrusion for boats with "self serve" mast stepping (like the trailerable boats), are aluminum rivets OK (like what you can do with the more standard pop rivet tools)?
Peter
Dec 28, 2014
61
Hunter 280 Mandeville, LA
If you have internal halyards be careful with the fasteners, don't want any sharp tips/burrs that might snag the internal lines, and keep the fastener as short as possible.
1,279
The good news is that it would not be a big deal to switch over to rivets, if you feel that is enough of an improvement - it's not like you drilled useless holes.
