Reinstalling soon
Are you re installing or installing for the first time.I will be reinstalling this week. I expect to simply reverse the procedure I went thru last fall - remove small access panel at base of furler - attach sail to furler head - raise head while feeding sail into track - use Sailkote if needed to make sail slide better - once all up connect webbing loop at base of sail to shackle on furler tube.Should be straight forward - much like installing a furling jib except for a bit more difficult access. I hope your message does not imply that I am in for a nasty surprise.
