Too many things to go wrong...
when you start putting check valves or Y valves in the bilge pump discharge lines. What if something fails when you need it the most? If either of the check valves gets debris in it and is stuck in the open position, neither of the pumps is going to do you any good. If you need to use both pumps at the same time, the Y valve won't let you. What if you forget to put the Y valve in the correct position? If something really bad ever happens and those bilge pumps are the only thing between you and taking a swim, I'd want to know that they were both fully independent and ready to go, without having any valves to mess with or other little gizmos that could go wrong. Just my two cents worth,Jeff
