Installing battery
John_F
Feb 24, 2009
34
Beneteau 31 Buffalo
Yes, this is an elementary question. But what is the best way to install a battery? I have to replace my old battery and the last time I did so, sparks flew.
Is it best to put the negative on first, then the positive?
Or, what is the best/safest way to do this?
Thanks.
Sep 28, 2008
922
Canadian Sailcraft CS27 Victoria B.C.
Install the battery with the main switch off and there should not be any sparks.
Nov 18, 2010
2,441
Catalina 310 Hingham, MA
Main switch off and negative first is how I was taught.
On the positive side, the last thing I do is put the fuse in. So you shouldn't spark connecting the positive anyways because it won't be a completed circuit until the fuse goes in.
7
Hunter 31 Port Jefferson, NY
You change the battery in your boat just like the battery in your car. You remove the Neg. (-) terminal first and this is so when you remove the Pos.(+) terminal if you accidentally touch grounded metal with your wrench nothing will happen. It is reversed when you put your new battery in, (+) first and (-) last.
May 24, 2004
7,213
CC 30 South Florida
Battery switch off will isolate most loads. You may have a hardwired bilge pump but that will only produce some light sparks. Regarding which to connect first, it does not matter.
