A friend of mine has asked me to install an electric bilge pump for him. That in and of itself is not a problem for me. I can do that.
Currently he has a manual whaler-type bilge pump located in his aft lazarrette, I suggested, and he would like to, to keep the manual pump for redundancy. I've thinking of ways to do this without running a separate line for the electric pump.
If you have installed and electric pump, keeping your manual:
- Did you run a separate line?
- Or did you use a Y-gate and check valves to use the existing discharge line with a by-pass around the manual?
I'll be working on a diagram meantime and post it to show you what I'm thinking.
Thanks,
Alec
Thanks,
Alec
