Guys, my 192 has the typical backstay with about an 18" strop from chainplate to triangle bracket, and then on up to the masthead, with the mainsheet on the other corner of the triangle bracket.
I'm considering the idea of putting an adjustable tackle, probably 4:1, in place of the strop. I know I saw pics of a 3:1 that someone had from the review article in Small Craft Advisor a year or so ago.
Probably the easiest is with a Harken 4:1 fiddle as illustrated third down on this page: http://www.harken.com/content.aspx?id=3897 and using some nice 1/4" Dyneema cored polyester covered line.
My problem is how to mount the system to the chainplate and triangle plate? All the blocks I've looked at seem that if I used another shackle such that the pin goes through the plates, then the system would be turned sideways, with the line exit off to the side, rather than forward back into the cockpit.
Have any of you retrofitted an adjustable backstay? If so, what parts did you use, and how did you attach them all?
Thanks,
Brian
Thanks,
Brian
