Tim
I just bought an Raytheon wind speed indicator, now the hard part, I need to install it. Can anyone give me some pointers on how to do this? I'd rather not remove the mast. I can't tell if the wires that currently go up into the mast (a coax for the vhf antenna and a few wires for the mast lights) are attached inside the base of the mast or not. If not, I could pull the coax down through with a return line attached. The lines then run through the compression post, but are so tight at the exit point I can't move them. Any Ideas??Regards,Tim
