installing a stereo system in a 320
Ken H
Oct 18, 2007
10
Hunter 320 Grand Rivers, Ky
I would like to install a stereo in my 320 and wanted to run the speaker wires from the main panel at the nav station to the top of my bimini frame. Any ideas on how to do this?
steve rainey
stereo
for whats its worth, I was on this track til I talked myself out of it. Makes more sense just to bring onboard a boombox and be done with it. Don't have to make any cuts in your boat, mount anything. don't have to run down your batteries, I talked myself out of a perm install...
Aug 9, 2005
772
Hunter 28.5 Palm Coast, FL
Yes, you string the wires a few feet at a time...
you may have to drill holes, us a fish tape and wire ties as needed. There is no simple answer to you question.
G
Gary
Partly easy
Part of that will be easy. The H320 has a wiring conduit that runs from behind the main panel straight back along the port side and ends in the aft lazaret above the fuel tank. If its never been used before, Hunter leaves a cord tracer in the conduit that can be used to easily pull the speaker cables. There are also speaker cables that in the main wiring loom too. They go from the main panel to the ceiling in the aft compartment. Gary H320 TimeBandit Emeryville, CA
