Good Day
I have a 93 Hunter 33.5 that I'm installing a new auto-pilot in. I've mounted the ACU and the Evolution autopilot in the rear closet close to the electrical panel. The P70s (control head) I've mounted in the same location as the old control head which was on the port side coaming.
My question is because of the long cable run from the control head to the ACU the only cable that came with the AP that is long enough is the one with the blue ends.
The P70s has white cable that attaches to it. then I will have to use the blue cable to make the run to the back bone. If i plug into the blue socket will the data get to where it needs to be?
Evolution Cabling Kit
Thanks
- 1 x SeaTalkng Power Cable (0.4m)
- 1 x SeaTalkng Backbone Cable (5m)
- 1 x SeaTalkng Spur Cable (0.4m)
- 1 x SeaTalkng 5-way Connector Block
- 2 x SeaTalkng T-piece Connector
- 2 x SeaTalkng Terminator
Thanks
