Installing a cleat in the anchor locker
Oct 24, 2024
16
Catalina 28 Mk 1 Oak Harbor
We have a Cat 28. I was advised to install a cleat in the floor of the anchor locker cabinet. Is the cabinet wall material strong enough to hold a cleat under tension? Thanks
If you have access.... I would add a backing plate. If you can create access... I would make the effort. A cleat in the locker is nice. I had one on my H26 and found myself using it all the time.
Mar 26, 2011
3,809
Corsair F-24 MK I Deale, MD
I assume the boat has bow cleats suitable for anchoring.
The anchor point in the locker is typically for the bitter end of the rode and is usually a u-bolt, not a cleat. Ropes snag on cleats.
If just a cabinet back ... perhaps not. A backing plate, of course, but look at it (post pics?) and decide. In theory, this anchor point never takes the full load of the rode. It is only to prevent the rode from running out if you have a brain fart. There should be an OBVIOUS warning mark on the rode at least 20 feet from the end. At least a meter or RED. You should never see this mark. But it can take quite a wallop if the boat drifts back on the rode, easily 200-400 pounds.
If you have a bow eye on the stem outside the hull there maybe an opportunity to create a stop for the rode.
The bow eye on the stem could/should have a backing plate inside the hull and probably accessible from the anchor locker. You could back the nuts off, put a pad eye or other hardware with the corresponding hole pattern over the backing plate and replace the nuts. The boy eye would be the backing plate for the pad eye. It should be way strong enough to serve as an endpoint for the rode. With luck you might not have to drill or caulk. It will take some shopping and looking at dimensions.
Likes: Surfside
Sep 24, 2018
3,810
Catalina 30 MKIII Chicago
Use your bow cleats. They're already reinforced. Having something to tie the end to so you don't lose your anchor or rode is helpful. Been there done that. I thought I could stop it before it went overboard. We still laugh about that to this day
Likes: Ward H
Jun 17, 2022
363
Hunter 380 Comox BC
You'll have to inspect the structure and probably drill a hole to confirm the thickness.... Definitely use a backing plate.
Oct 24, 2024
16
Thank you for the comment. The anchor locker floor material seems very thin to me. With the backing plate, it is probably fine just to ensure we don't lose the rod. I wouldn't want to place any tension on the fitting. It is accessible from the front berth.
Oct 24, 2024
16
I think the anchor cabinet material is pretty thin, maybe 1/8.
Oct 24, 2024
16
I think I will install a fitting with a backing plate, but only to secure the anchor line and not as an anchor point. We have cleats on the bow.
Thank you for the comments.
Oct 24, 2024
16
Thank you
Oct 24, 2024
16
No warning mark on the rode. I will follow your advice. The material is maybe 1/8, so this is only to secure the end of the rode. Thank you
Sep 24, 2018
3,810
Use your bow cleats. They're already there, dont require any reinforcement and are easier to tie off to than one inside the locker. I have both on my C30. The one in the anchor locker is awkward to use. It is useful to ensure that I don't lose an anchor when letting line out
Jan 7, 2011
5,812
Oday 322 East Chicago, IN
I do not have a cleat in my anchor locker. I always cleat off the anchor on the bow cleats. I lay the bitter end of the rode up to the opening in my anchor locker so I can close the locker.
Works fine.
