Just keeping the top clean
Thanks for the response. I just want to keep the top of the boat relatively clean from birds, dust, etc. I have a 12 volt washdown pump from West Marine that my wife bought me for Christmas. On the boat I have two 12-volt batteries. My guess is that I will use the pump once a week for 5 to 10 minutes or so to hose off the topsides. I thought about hooking it up in one of the rear storage lockers. I guess I could mount it in the anchor locker. I was thinking of just teeing into one of the thru holes and running the electical to the power center. The questions I have are which locker would be most convenient. Should I put in a fixture for attaching the hose on the outside. Just using lake water for the cleaning would be fine. There would be no tank needed so only winterizing would be to make sure the pump itself is either drained or has antifreeze in it. Where I keep her docked, I do not have running water or power (other than my solar panel for recharging the batteries). The way I clean it now is to take it up to the gas dock and wash it there. Sort of a minor pain I am trying to get rid of. Let me know if you need more info.
