battery #2
I have a 1979 catalina 22. I have two batterys and there was PLENTY of room to install the second battery. If you have a load connected to the battery that is drawing "juice" from the battery then if will take longer to charge the battery. How big is the charger on the Honda? I figure 10 amps plus or minus (check owners manual). That means if your battery is connected to a load and your Honda is charging and the load is 11 amps (lights, vhf, stereo, etc. for example) you are still dischaging your battery at 1 amp per hour. (based on a hypothetical 10 amp alternator output). Basicly, you have to know what is your load, in amps, and how long are you running that load. This will give you the amp/hours. If your load of 20 amps is used for 1 hour (20amp/hours), then you must charge your battery 20 amps for 1 hour to make it whole again. If your alternator on the Honda puts out 10 amps (hypothetical), that means you would have to run the Honda for 2 hours to recharge your battery(s). There are many marine electic books available that can explain it better than this. I would point out that while I have 2 batteries I actually only discharge one during a weekend. Two batteries are good because it is always nice to have redundency on a boat. Keep in mind though, that most of the time you will be sailing and (hopefully) you are not listening to the Honday charge your batteries!
